Re: Salt Level not showing actual values
BogeyGolfer
I have been having the same problem. I have an Aquarite Goldline generator. I replaced the cell about a year ago. It was working fine until lately it showed low salt levels at about 1800. My local pool store checked the salt and it read 4000! There is no chlorine being generated. I inspected the cell and cleaned it with a muriatic acid solution. It still reads low salt. Could it be something else like the flow sensor?
BogeyGolfer
Well I bit the bullet and ordered a replacement cell today. I was hoping for a less expensive fix. Thanks for the advice.
mas985
Are you sure you cleaned the cell well? A cell should last much longer than a year.
Unless it was one of those new "economy" cells only designed for one year, it should be under warranty.
