Thread: Clear green water
    Lehigh Valley, PA
    Default Re: Clear green water
    Welcome to the Pool Forum!
    Is it possible that you have metals in your water, iron or copper? Are you filling from a well? This thread may be helpful: http://www.poolforum.com/pf2/showthr...-won-t-go-away
    It's much easier to answer your questions, when we know something about your pool. We often spend the first few posts back and forth collecting information. So, please complete our new Pool Chart form -- it takes about 30 seconds, but will save much more than that.
    Pool Chart Entry Form
    Pool Chart Results
    Hi Rick;
    Typically, it's metals as AnnaK noted. And, you'll need to complete the chart, before we try to resolve the problem.
    Often, you can fix it temporarily by lowering the pH -- but not too much! We'll need to see test results, too.
