Introduction
Hello,
I dont really have a problem at the moment so just thought I would post an introduction. I have a 36,000 gallon IG vinyl pool with Hayward Super pump, Hayward DE 3620 filter and Hayward 250,000 gas heater. I have had a pool all my life and been in this house with this pool 7 years. This year alone I have replaced the motor on the pump, found a suction side leak that has been causing me trouble for a few years and replaced the heat exchanger in my heater. Next up is a liner replacement at the end of the season or in the spring. Right now the only problems I have is a bit of a high CC number so I will be shocking the pool this evening to see if I can knock that out. I have been reading the forum for a long time.
Lisa
- You may not post replies
- You may not edit your posts
Forum Rules
