I have a tremendous amount of white deposit on my tiles and suspect it is caused by the Salt water chlorine device as it produces enough calcium buildup on the cell plates to bridge the plates completely unless it is cleaned every day. My chemistry numbers are as follows.
CL = 5.5 CC= 0, PH =7.6, TA =70, CYA =60, Calcium Hardness =900-1000, Salt = 4200
I refilled the pool 20 months ago and the CA then was 200. If the high CA is not caused by the SWG what other things can be causing it?
