Results 1 to 10 of 15
Thread: Can't get a reading for CH level.
    Long Island, NY
    Default Re: Can't get a reading for CH level.
    Checked around the forum and noted that my stabilizer reading of -20 was actually none at all. So I went ahead, after backwashing the filter, and added a little over 2 lbs of stabilizer for my 20,000 gal pool as per instructions on the container. Didn't want to add the full 4 pounds as I don't want to overcorrect. I followed a 1/2 hour later w/ 4.25 gal of chlorox bleach.
    Still no reading for Clorine. Am I expecting too much too soon? Should I add more bleach?
    I am a little anxious about this as we are leaving on Sat for 3 days. Should I continue to leave the filter on 24/7 while we are away? The water isn't green, but still cloudy. How about clarifier? Would it help as well?
    Appreciate all your input very much.
    Winwillie
    mbar's Avatar
    Ashland, PA
    I would bring my chlorine level up to shock, and keep it there, by testing 3x a day and bring the chlorine level back to shock each time. It can take a week for the cya to show up. Don't backwash while the cya is dissolving. Keep the pump running 24/7 now. You can get a floating puck basket to hold pucks while you are away - but I would raise my ph up to 7.4 - 7.6 first, because the pucks will bring your ph down. The pucks are stabilized, so they will also add cya to the pool, that's one reason everyone here likes to use bleach. It would be great if you have a neighbor to check on the pool while you are away, but if not don't worry, the pucks will add chlorine while you are gone.
    Northeast PA
    Kentucky
    Unless you diluted the stabilizer in very hot water - you will likely need to wait a while to get any effect from it. Stabilizer (grainular) takes a long time to dissolve (a few days if you poured it into your skimmer)
    Also - if you added the stabilizer to the skimmer - be sure to NOT backwash for a few days, or you'll be backwashing the undissolved grainular stabilizer out of the filter.
    Keep your Cl level high for a while, and run your filter 24 hours a day until the water is clear. It will take a few days to filter out all the dead algae. I'm assuming your 'cloudiness' is not a dark green cloudiness, but rather a whitish color. If it's whitish (maybe very light blue, or very light green tinted) then you have killed the algae, and now just need to filter it out.
    The only quick fix is a clarifier or flock treatment for your water to help the dead algae settle to the bottom to be vacuumed out - however I don't recommend it - the filter will get it all in a matter of a few days.
    Sanford, FL
    The CYA will take nearly a week to dissolve all the way. So don't test it until next week.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Long Island, NY
    Had no idea the CYA read may not show for almost a week! Boy, I have alot to learn......Added more Chlorox another gallon & 1/2 container. STILL no reading. I can smell the chlorine so I know it's there! I do have some sticks in my skimmer. (Biogard) I am leaving my filter on 24/7 as you all recommended.
    My water is cloudy, but NOT green cloudy, so I'm assuming I'm pretty good on algae. How do I raise the Ph? One of the posts suggested that if I'm away for the weekend, I might want to raise Ph before adding sticks while I'm away.
    Don't know if I should be adding more chlorine.
    Thank you ALL! We are really trying to learn more so we can enjoy our pool for less $$ and less stress.
    Winwillie
    18 x 32 IG
    Long Island, NY
    If you're smelling chlorine, then you definitely need to add more--what you're smelling are the chloramines, which are produced when "goo" is being broken down in your pool by the chlorine.
    To raise pH, get a box of 20 Mule Team Borax from the laundry aisle at the grocery store and add it, slowly, through your skimmer.
