Re: Pump Doesn't Pump....Just Hums
I found this forum today as I *sigh* seem to be having the same problem here in Chardon, OH. Although when I reached in with my 7/16 and turned it back and forth (was able to do so - without getting shocked
it didn't seem to make a difference. Here are details: pump certainly seems to be running ok (starts up ok) but I have low flow. I am going directly to waste (bypassing the filter). I replaced all suction side pipes and it is air tight. In fact, when I turn off pump, I hear a swoosh of water that kicks back into the basket from the pump. When I open the basket lid the presuure relieves. So it seems like I have plenty of pressure but the water doesn't want to move for some reason (well, a little bit of water is moving but not much)...the pressure gauge isn't moving - just site at 5psi. I reached in and checked impeller which moves fine and doesn't appear to be clogged. It looks like I might have to tear the pump apart? Any other ideas on what's happening? Thanks very much for any insight.
