Re: Afraid to shock new liner
Safe shock level depends on your CYA (stabilizer) level. Test your water to determine your present CYA level and you can find your corresponding recommended shock and maintenance levels on the 'Best Guess Table" below.
Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
=> 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
=> 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
=> 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
=> 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
=> 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
