Thread: New Member
    Jun 2012
    Vermont
    Default New Member
    I have a 20 year old IG 16 x 32 FOXX pool that I just had a new liner installed. We never have any good luck with the typical skimmer type vacuum. I do not have the booster pump for a pressure type cleaner. My only option I believe is a robotic cleaner. I am so confused reading all of the negative/positive/negative/positive reviews, I do not know what to believe. All I want is a unit that will clean my 8 ft deep pool without any major problems. I do not mind tinkering with things but I do not want to get ripped off with a lemon.
    Is there really a truly good unit that is reasonably priced that will last at least 5 years with proper maintenance for 4 moths out of the year.....
    Thanks for listening..
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: New Member
    Quote Originally Posted by salvc921 View Post
    There are pressure cleaners that do not require a booster pump such as the Letro Legend II and the Polaris 360.
    See above
    probably not but it really depends on what you consider truly good and reasonably priced
  1. New Member: Please Help
    By freetime in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2013, 06:18 PM
  2. New member
    By 7sanders in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-10-2012, 01:27 PM
  3. New Member-CYA
    By 392papa in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-14-2012, 10:43 PM
  4. New Member
    By amyjtaylor in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2012, 03:02 PM
