Thread: First "Pool-tastrophe" survived...mostly
    May 2012
    Johnstown, PA
    Default Re: First "Pool-tastrophe" survived...mostly
    Posting this to report that the DE has helped to clear my water. It has been a battle but my water is finally crystal clear. This has tested my patience but I think that all the trouble has been worth it.
    18 x 36 30,000 gal. IG
    1 1/2 HP Hayward Superpump and S244T sand filter
    That's good to hear. Hopefully that's the last tornado you'll see this year!!
    Jul 2013
    Northern Illinois
    Hello! Glad to see you online? How are things with the pool?
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  2. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  4. Timer to motor and aquarite..."Y"or "T" fitting?
    By BND in forum Pool Equipment & Operations
    Last Post: 04-23-2007, 03:59 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
