Cloudy water after filter change
First I just want to say thank you so much for teaching a man "how to fish." The pool stores just want to "sell me their fish." God forbid you ask them "why" you have to buy all those chemicals and put them in your pool. The knowledge I have learned on this site will last a lifetime (or at least until old age sets in).
So I opened my pool about 3 and half weeks ago. It is around 27,000 gallons/vinyl. I shocked it with 3lbs Power Shock (97% Sodium Dichloro-s-trianzinetrione) and added 1 bottle of Agicil (60% Poly [oxyethylene (dimethyliminio) ethylene (dimethyliminio) ethylene dichloride])...probably didn't have to type all of that out, but I want to be thorough.
After the water cleared up I vacuumed the pool and headed over to the pool store for a water test. At that time the water was on the cloudy side, but I just vacuumed and that probably kicked up some stuff that I figured the filter would catch.
Their results:
FC: 0 TC: 0.7 CC: 0.7 pH: 7.4 Hardness: 137 Alk: 106 CYA: 28
They told me to add 3lbs more of shock and another bottle of algaecide and fill my dispenser with Mini-Tabs (1in tablets of 99% Trichloro-s-Triazinetrione). They also gave me a Hardness Control which I did not end up putting in. The next day looked great (in retrospect it was not crystal clear like your Day 4 picture on the bleach demonstration, but it wasn't cloudy either).
After a weekend of swimming I shocked the pool again (3lbs). A couple of days later I noticed that I had a crack in my filter at the multiport valve where the return line came in. Since our old filter company went out of business (Jacuzzi) we decided to get a new filter (sand-Pentair SD80) rather than try to repair. Unfortunately I had to wait over a week to get it installed and the water became so cloudy that I could not see the bottom. After it was installed I shocked it with 3lbs and let the filter run for 2 days and there was no improvement. It also may be important to point out that I have an Aqua Genie skimmer which dispenses my Trichlor tabs with a spillover, so when the filter is not running, the dispenser doesn't work. In retrospect, I should have made sure that something was providing chlorine to my water, but not sure if that would have mattered without circulation. So I went to the pool store and got a water test and told them my problem.
Their results:
FC: 0 TC: 0.6 CC: 0.6 pH: 7.6 Hardness: 246 Alk: 65 CYA: 10
They told me to shock the pool again (3lbs) and add 6 capfuls of Alum (aluminum sulfate) to my skimmer as a sand filter aid. A capful is not much, probably 1/4 of a cup. They said that it may take awhile and to backwash my filter after the gauge goes up 10psi and repeat until the cloudiness is gone. Cloudiness did not change at all and my psi did not budge (maybe 1-2psi).
Since then I have been trying to consume as much knowledge on poolforum and poolsolutions as possible. Last night I got an OTO test and 7 bottles of 1.42G of generic bleach, some borax and baking soda from walmart. My chlorine test was clear, showing no chlorine. The pH was around 7.2. I added 4 bottles of bleach to raise the chlorine to around 10ppm. This morning I tested everything with my K-1005 kit that I bought last year (K-2006 is in the mail). I got the following:
FC: 1-2 TC: 5-10 (probably higher) CC: >8 pH: 7.2 Alk: 60 CYA: 0 (water was clear).
After the reading, I decided to raise the pH with 2 cups of borax this morning. When I got home from work the water still looks cloudy, but I feel like I can see further into the deep end. Here are my readings from tonight at dusk.
FC: 1-2 TC: 3-6 CC: 2-4 pH: 7.4 Alk: 60 CYA: 0 (water is clear).
Sorry for this ridiculously long post, but I wanted to give you ALL of the details. After reading through this site, I feel like I have never been more prepared to care for my pool, but first I need to clear this cloudy water.
I hope you can help.
Jim
