Re: New to SWCG Pools HELP
Thank you so much for help. I find it interesting that a very large commercial pool builder, which I consulted, uses the Aquasalt product when he could save quite a bit of money using the products you recommend. I will use your recommendations. It will save me about 50%, thanks for the cost savings!!
How do I order the Taylor 2006 test kit so that the forum gets credit?
I tried to go to the sticky that you suggested on water balancing but was not allowed to view, what did i do wrong? What do I need to do?
Thanks again not only for the help but for the forum. I know it must be alot of work. It is greatly appreciated!
Dakota
