Results 1 to 9 of 9
Thread: Pool Details (as requested)
    Jun 2012
    Whitby, ON
    Default Pool Details (as requested)
    'netiquette suggests searching for an answer before posting a question however I understand the need to filter out the spammers we all despise. In keeping with 'netiquette I'll just post my pool details;
    approx figures:
    16'x32' "Californian" (kidney-ish shape)
    16,500 gallons
    Pentair minimax plus 250M heater NG
    Pentair WhisperFlo pump
    Hayward brominator
    vinyl liner
    Default Re: Pool Details (as requested)
    Welcome to the forum! Is there a question that you have?
    If there is something you would like to search for information about, please use the Google Search in Janet's signature above instead of the search feature that is built into the forum software. Until your registration is complete, you will have to log out to see the results, however, but that is only a temporary inconvenience.
    Jun 2012
    Whitby, ON
    As a matter of fact there is, thanks fer askin';
    I am getting tired of the cost of bromine and the constant requirement for baking soda, so I'm thinking of purchasing a Salt Water Generator for my inground pool. I want to convert from bromine to salt. It's my understanding from talking to neighbours that the cost to run a salt water pool are significantly less than bromine and the water chemistry is more, "self-regulating" I guess - for lack of a better term.
    I've read a lot of complex and frankly heady online opinion on the matter and I don't have a lot of faith in the local pools guys opinion. He says I just need to install the generator and throw a bunch of salt in the water. Online opinion suggests I need to completely replace the pool water (using large poly tarps and such to ensure water is always present).
    What's the truth on how to switch from bromine to salt? And, is salt really that much cheaper than bromine to operate?
    I would think that salt is a lot cheaper than bromine to operate, if you don't count the initial cost of the equipment and starting doses of salt and chems to get the chemistry right. With a SWCG, you're basically looking at muriatic acid to control pH, salt to maintain your levels, and occasional doses of bleach IF you need to shock. Those things, compared with the cost of bromine, are MUCH cheaper.
    However, I don't know about what's necessary to convert from bromine to chlorine, so I'm going to let Pooldoc, Waterbear, chemgeek, or one of the others familiar with bromine systems address those questions. The forum is extremely busy this time of year, so it may take up to a few days before one of them pops into this thread, but be patient--they will come!!
    Jun 2012
    Whitby, ON
    Thanks aylad,
    I spend about $300/season on bromine (+ baking soda). I'm thinking a SWCG at $900 should pay for itself in 3-4 years so as long as we don't plan on moving, it makes sense financially.
    Watermom has asked Ben (Pooldoc) to take a look at this thread and he should be able to give you the necessary info about the bromine.
    Hi Rob;
    I wouldn't get into a hurry. If you are spending $300/season for bromine, you probably aren't going to save enough to pay for the SWCGs. Some what you've been told is mistaken, but some is not.
    In particular, if you've been using sodium bromide with chlorine or something else as an 'activator', it will be enough to drain most of your water and replace it. But, if you've been using bromine tabs -- BCDMH; bromo-chloro-dimethyl hydantoin -- you pretty much need to drain 105% of your pool's water. As best we can tell, DHM (dimethyl hydantoin) greatly reduces the rate of conversion of bromine to bromate (stable, non-actor in pool chemistry). And draining a vinyl pool that completely is both tricky and risky.
    Here's a quick rundown on SWCG's
    + provide a stable and effective method of continually adding chlorine to a pool.
    + reduce likelihood of algae, due to constant chlorine feed.
    + reduce the need to store hazardous chemicals with damaging fumes
    + can be somewhat easier to operate
    + make it much easier to leave the pool for a few days, or go on vacation.
    BUT
    - cost more than you think for salt & electricity
    - often require expensive cell replacement every 2 - 4 years
    - can result in salt corrosion or damage, especially of natural deck stone
    - require controlling calcium levels more tightly than you may have done
    - often bring a continuing upward pressure on pH levels.
    - only work well when the pool is operating normally; you'll need to switch to manual operation during start-up or algae episodes.
    If I were you, I'd try to do a switch to chlorine + stabilizer this year, and think about an SWCG -- possibly after a 2nd drain and replace -- next year.
    You can do a 95% in place drain of a vinyl pool, if you get a winter cover that is 16' oversize in both directions.
    Jun 2012
    Whitby, ON
    Thank you for your detailed response Pooldoc. You've given me a great deal to think about.
    We moved to bromine from chlorine years ago because my daughter was showing some allergic symptoms when she was in the pool (mostly sneezing), so I can't see a move to chlorine being welcomed by the family ;-)
    I think I'll just stay the course with bromine.
  1. new to the forum / pool details
    By argile in forum Dealing with Algae & Slime
    Last Post: 06-16-2012, 03:58 PM
  2. green pool..see details
    By spacechimp in forum Dealing with Algae & Slime
    Last Post: 08-29-2010, 01:01 AM
  3. SWG Cell install opinions/suggestions requested.
    By Beautye350 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-31-2006, 02:12 AM
  4. Feedback on my test numbers requested
    By portlandpool in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-05-2006, 10:52 AM
