Thread: Hayward DE filter EC65 - when to replace the "fingers"
    Jun 2012
    Michigan
    Default Hayward DE filter EC65 - when to replace the "fingers"
    I am on my second EC65, first tube platter busted, and I found a replacement filter as used.
    Now after 8 years of faithful service, the least pressure I can get with water moving thru the filter is 23 PSI. With the 6 lbs of DE it is basically starting out at 28psi. When it hits 38 not much is moving thru.
    I have done the Soap and acid baths, but when do you say it's time, and bite the $450 solution?
    I have a 20x40 inground with a 1 hp Superpump 220 volt.
    Thanks for your reply.
    Default Re: Hayward DE filter EC65 - when to replace the "fingers"
    IF the filter pressure is starting high and rising very fast even after degeasing and acid washing it's time!
