Results 1 to 10 of 13
Thread: Brown pool
    Jun 2012
    Heartland USA
    Default Brown pool
    I need help. We opened our second homemade inground pool this year that we fill with river/stream water. Are previous pool of 3 years was also filled with river/stream water and was about 10,000 gallons. It started with brown water, high Alkaline and normal PH. After decreasing the Alkaline and running pump for about a week straight the water would become crystal clear. We increased our pool size to about 18,000 gallons by making a pool from a grain bin placed in ground and lined with a pool liner. We started with the same river/stream water. It has Alkaline above 300 and normal PH. We knew nothing about the BBB method. So we have used chemicals to get the Alkaline normal, added Algeciide, Shimmer, Rust and Scale out, and Trichlor Tablets. The pool was getting almost clear except the middle of the pool. All readings for Alkaline and Ph were normal. The Chlorine reading was at 0. So we shocked and added Cyanuric Acid to the pool. The next morning the pool is even more brown then when we filled it. The Alkaline, PH, and Cyanuric Acid were normal, the Chlorine was 3. I took the Trichlor feeder out as I felt the shock did something to the pool. Any ideas what to do next? We have been at this for 3 weeks. I know this river/stream water in our pool will clear, but I'm not sure why it is not.
    Default Re: Brown pool
    It sounds like you have metals in the water, which isn't a surprise for river/stream water. If that's the case, high chlorine will cause the metals to precipitate out and create the brown color that you're reporting. Can you take a water sample to the pool store and ask them to test it for metals?
    If you do indeed have metals in the water, then you'll either need to add a metal sequestrant to keep them in suspension (these are broken down by chlorine, so when you see the water starting to discolor again you'll need to add another dose) or to filter the metals out of the water by running it by a high chlorine source right before it goes into a filter, so the metals will drop out on the filter and you can get rid of them that way.
    What type/size of pump and filter do you have on this pool? What are you using to test your water with, and what are your levels for pH, alk, and CYA?
    Welcome to the forum!!
    Quote Originally Posted by Riverpixy View Post
    Unfortunately, that tells us nothing. I looked to see what you are using, and it seems to be a strip based reader. Those tend not to be very accurate, and can be wildly inaccurate. Plus "normal" means whatever the techie dude who wrote the software for the reader THOUGHT was normal, but I have no idea what that would be.
    Other comments: surface water quality can vary from season to season, and even year to year. There's no guarantee that the water you put into your pool THIS year is much like the water last year. That's one of the things that makes running a big city water utility with surface (river) water so challenging.
    Read this page: http://www.poolforum.com/pf2/showthread.php?16946, and then do a bucket test on BOTH your pool water and the river water.
    I don't know, but odds are the fastest and best way for you to get a clear pool is to drain and refill, but only AFTER we know what's currently in the river water AND you have a good test kit. The K-2006 is the only kit we know of that's trustworthy. If you want to wait, I was planning to run comparison tests on an AquaCheck TruTest, but not till August. Waterbear may know . . . but I'm guessing you're going to have to a get a Taylor.
    waterbear's Avatar
    St. Augustine, Fl
    You need a Taylor K-2006, the Trutest is a toy. NOT worth the money it costs (then again, no strip reader is worth the money it costs).
    If you don't believe me you might want to read the reviews of it by customers on Amazon. One in particular was interesting where they water was retested 5 times in a short period and the pH varied between 7.0 and 8.1 and the alkalinity between 95 and 185 ppm. In other words, the test results are worthless.
    Jun 2012
    Heartland USA
    I don't know what happened to my reply to aylad because I had all the details about my pool and what I have used. Just a brief answer to the Questions that were asked:
    (What type/size of pump and filter do you have on this pool?) It is a Sta-rite (larger one) with a 1/5 H.P. pump.
    (What are you using to test your water with) I was using Aqua Check strips and teh Aqua Chek reader and strips.
    (and what are your levels for pH, alk, and CYA?) With the strips the Ph was 7.4, Alk - 80-100 and Cya was low to normal - all of these vary with the test strips and meter
    (Can you take a water sample to the pool store and ask them to test it for metals?) I did. Pool store was no help as they just used the strips and did not even follow the instructions. I took a sample to a water softener store. They said they did not find metals but PH was 7.3 and Alkaline was 180
    So I felt the Alkaline was the problem and continued to work on decreasing it. Now my pool is clear! Yeah!
    Since I found this pool forum, I started to read that that the strips and Aqau chek reader were not reliable. The Aqau chek reader has been terrible and is going back! I have been reading about your TF100 and K-2006 comparison. I am going to order one of these. Which one do you recommend?
    Also I see you have recommend household bleach for chlorinating? The shock I used was Calcium hypochlorite, which turned the water brown immediately. I also have Sodium Dichloro-s-triazinetrione, which I think is better? I have trichlor tablets in my floater. What are your recommendations about chlorinating?
    I like this forum and I think I will learn a lot and I really need the help. I can't get much help from pool stores around here.
    Jun 2012
    Heartland USA
    Ha-Ha. I just posted a review on Amazon. Wish I would have read that before ordering!!!! The Trutest is terrible and is going back to the store!!!
    I think you'll be very happy with the K-2006--it's nice having reliable, accurate testing at hand!!
    Bleach, cal-hypo, and dichlor are all acceptable forms of chlorine. The fact that your water turned brown was not because you used cal-hypo, but because you put in a large amount of chlorine at one time. If you'll keep your pH low (7.0-7.2), and stay on top of your chlorine so that you don't have to shock the pool, as well as keeping a metal sequestrant in the water, then you shouldn't have any problem keeping clear water all summer. You might want to add a dose of Polyquat 60 algaecide (the only one that we recommend) as an added protection against algae. The dichlor and trichlor will add chlorine and help keep your pH low, but you'll need to keep an eye on your stabilizer levels, since they both add CYA....and the higher the CYA, the higher your chlorine will need to be in order to keep the algae away.
    Jun 2012
    Heartland USA
    Thanks Janet. I have added the Polyquat 60 algaecide. I've added Metal sequestrant -probably too much. The pool store kept telling me to add it. I have put 5 -32oz bottles in the pool.
    Both of my current substandard tests that I have right now do not even measure Chlorine yet. I just did a little test with the shocks that I have bought. Honestly when l add the Cal-hypo it turns brown when it hits the water. When I add the Sodium Dichloro-s-triazinetrione it does not. I have one trichlor 3" tablets in my floater in the pool for at least a couple of weeks. I would think that alone would measure some chlorine. I need to work on getting Chlorine level up, but am scared too because of past experience. What would you suggest to get the chlorine up? Should I use the Sodium Dichloro-s-triazinetrione shock I have or should I just use some household bleach? Should I add another chlorine floater?
    My pool is clear now. So just need to keep it that way. My readings on my trutest reader (which I know is unrealiabe) were Chlorine 0, PH - 7.2, Alk - 115.
    I am going to order the Taylor K-2006.
    I really appreciate this forum. So glad I found it. I have learned more from this forum than I have with working with pool stores for 4 weeks!!
    The polyquat creates a chlorine demand of its own, so I'm not surprised that your chlorine now is zero--but you can't let it stay there long I suspect that your chlorine is also working pretty hard on the stuff that's in your water, so it's probably going to take some diligence to get chlorine to hold for awhile. You can keep the trichlor in the floater, which will help feed chlorine in pretty constantly--just keep an eye on your pH. Otherwise, the dichlor would probably be okay, but honestly I would go with plain, unscented bleach. With all the other things you have going on in the water, bleach is the least likely to complicate things worse than they already are. Besides, it's much easier to calculate doses. What is the volume of your pool?
    Jun 2012
    Heartland USA
    I think I found out what I did wrong when I sent my original reply to your very first response to me. I think I hit the reply to thread button again to send my reply instead of hitting the post quick reply button! I just did it again.
    My pool is around 18,000 gallons. So how do I calculate how much bleach to use? How often do I add?
    I just ordered my Taylor K-2006 kit. Pool Supply World had it for $45 with $8 shipping.
    Thanks,
    Diane
  1. brown pool water
    By tlwilliams05 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-03-2011, 11:47 PM
  2. Pool liner is brown
    By shamrock in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-27-2011, 04:29 PM
  3. brown water from well in pool
    By Hanna in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-04-2011, 08:13 AM
  4. brown, green pool
    By vwb1975 in forum Dealing with Algae & Slime
    Last Post: 07-06-2006, 12:52 PM
  5. New pool, brown water
    By diwilson in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-12-2006, 02:24 PM
