Thread: Green & Cloudy Water
    Default Re: Green & Cloudy Water
    Yes, try the skimmer sock and keep hammering it with bleach. Also, you don't need to backwash every day. It is best if you don't. The rule is to backwash whenever your filter pressure rises 8-10 psi over clean filter pressure.
    Pamsel is offline Registered+ Thread Analyst Pamsel 0
    Central Illinois
    I didn't know that about backwashing, Watermom. Thank you for your help and I'll just keep at it with the bleach and will add the skimmer sock. I'll let you know when it's sparkling in the sun. :-)
    Pam, Illinois
    "17'x33' oval 14.5K gal IG vinyl pool; liquid chlorine; Hayward Pro Series, M-S-244T sand filter; A.O. Smith Centurian, Switchless, 1.40 HP pump; Right now 24/7hrs; Pool Solutions PS234
    Serial #6511, Drops / Powder; Community well; summer: none; winter: mesh; ; PF:8.3"
    Just to add to what Watermom said, a dirty filter will actually filter water better than a clean one--less space for junk to get through....
