Results 1 to 10 of 21
Thread: Pool Calculator; useful?
    Jun 2011
    Northern VA
    Default Re: Pool Calculator; useful?
    Watermom - Thank you for the link to the pool calculator, this is the first time I have seen this. I am not fond of the first one that was referenced so I try to do the calculations myself but apparently I am not very good at it - hopefully my problems will disappear now.
    JimK - I just downloaded the calculator and it is working.
    27 ft x 52 in AGP
    Hayward Power flo LS 1.5 hp - Hayward model s180t sand filter
    27' round 17.2K gal AG pool; hand fed; Hayward model s180t sand filter sand filter; Hayward Power flo LS 1.5 hp pump; 24/7hrs; Taylor Complete FAS-DPD Pool Water Test Kit K-2006; orig. truck but use well to resupply; summer: ; winter: ; ; PF:7
    Good! Glad to be of help!
    Shifty is offline Registered+ Thread Analyst Shifty 0
    Jun 2012
    Pennsylvania
    Jim,
    I don't think waterbear is telling you not to use the pool calculator, rather saying "proceed with caution." If you can reasonably estimate the volume of your pool (there is an estimating tool at the bottom of the calculator) and you know how the different chemicals react with one another (i.e. trichlor raises CYA and chlorine, but is acidic and lowers pH), it is a useful tool to use. I find myself mainly using the pool calculator for doses of bleach and borax.
    American Titan SS DE Filter; Multiport; 18'x36' grecian 24K gal IG krystalkrete (super blue) plaster; BBB and trichlor pucks for CYA; Hayward SP3400VSP Ecostar; Taylor K-2006; The Pool Cleaner Auto Vac (4 wheels)
    Lehigh Valley, PA
    I second what shifty wrote. I can't use the bleachcalc because it's a Windows executable and I run a Mac. The Pool Calc is HTML based and runs on any platform. Like you, I use it for bleach and Borax calculations and occasionally for "effects of adding xyz". It has never lead me wrong but I now have enough experience with my particular pool to know when I should question any results obtained. The caveat I follow is "add half now, test, add more later".
    Mar 2012
    Tennessee
    I started using the pool calculator this season. So far, so good. Have found it to be very helpful. Able to keep all levels where they should be. Pool is crystal clear.
    1 1/2hp Emerson 2speed pump, BBB
    27' round 19.3K gal AG Vinyl Liner pool; sand filter; pump: 24 hrs on low; Taylor K-2006 FAS-DPD Chlorine; utility water ; PF:6.9
    Virginia
    Quote Originally Posted by Shifty View Post
    Jim,
    Quote Originally Posted by AnnaK View Post
    Quote Originally Posted by tnalaskan View Post
    Thanks. I appreciate the clarification and feedback.
    Some use it and swear by it. I never do.
    I figure 1 gallon of <n>% bleach in 10,000 gallons of water raises FC by <n>ppm. It's a convenient rule of thumb based on the actual formula: (1,000,000/pool vol) * (bleach concentration) * (amount of bleach) = FC increase.
    Jul 2012
    Cincinnati, OH
    Watermom.....thanks for the link...that will be a big help getting me started on BBB!!!
    18x40 Lazy L 30K gal IG Vinyl pool; tri-clor feeder; Hayward #250 sand sand filter; Hayward super-1-1/2 HP pump; ; Taylor 2006c; utility water- PF:4
