Thread: Calcium and hard water
    Jun 2012
    Ohio
    Default Calcium and hard water
    I have very hard water and when I add water to the pool it raises the Calcium hardness significant (greater than 800ppm). The water gets cloudy. Are there any recommended calcium reduction techniques or chemicals
    Colin
    Default Re: Calcium and hard water
    Ben (Pooldoc) has a method he's been working on to remove the calcium from high-calcium water, but he's the one that would need to explore this with you....sit tight, and hopefully he'll be by soon...
    Welcome to the forum!!
    It's done:
    http://www.poolforum.com/pf2/showthread.php?16992
    For what it's worth, this is the ONLY practical way to solve the problem, when your fill water is already out-of-bounds.
  1. hard water
    By nick1628 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-27-2012, 03:04 PM
  2. Salt Chlorinator doesnt work with hard water
    By danspive in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-17-2012, 01:40 PM
  3. Do SWCGs work in hard water?
    By aquarium in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-29-2006, 08:53 AM
  4. hard water, need help
    By marshallg in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2006, 09:26 AM
  5. Water is too hard
    By mphare in forum Dealing with Alkalinity and Calcium
    Last Post: 05-01-2006, 04:25 PM
