Re: WHIPPED CREAM in pool CLOUDY problem from the DAIRY and OIL
UP DATE: I added 10 times the amount of clarifier because a pool store told me to, then another pool store said the pool is now probably cloudy form that. So they told me to shock it again, so I did and continue to run the filter and clean the filter as well. Still is cloudy. There is a faint faint chalky ring on edge of pool and tiny partical that are in the cloudy water. I will try a enzyme thing and scum ball thing too today and keep my fingers crossed. The clorine levels and Ph are a little high but that is probably from the shocking. Keep the ideas coming before I break down and empty the pool and refill. I will keep you all informed. Thanks for all the responses thus far.=)
