I have been a pool owner since 31 May 2012. In the past 3 weeks I have successfully kept my pool water crystal clear from reading this forum. I have adopted the BBB method for the most part, with the exception of temporarily using trichlor pucks to raise the CYA to 50 ppm.
The last owner of the pool left behind a Taylor K-2005 test kit but it looks kind of old so I don't know how relaible the reagents are. Just in case, I bought an HTH 6 way kit as a supplement.
I have a concrete inground pool measuring 18 ft x 36 ft for about 24,000 gallons. I have a DE filter with an Emerson Motors 1 HP pump. I have been running the pump about 15 hours a day.
Readings as of 15 June 2012:
CYA 45 ppm
FC 2 ppm
pH 7.2
TA 70 ppm
TH 290 ppm
I have repeatedly had to vaccumm the floor around the returns. Do you think I may be low on DE and the debris is not being sufficiently trapped, thus being blown out the returns? I have not backwashed yet. The psi is slowly rising to just under 20 as of last night.
Thanks for your help.
