Thread: Can you swim with High CYA
    Lafayette, La
    Default Can you swim with High CYA
    I have read conflicting info on this. However in reading some of your posts it appears that people have left their cya high and just switched to Bleach instead of a Tri-chor or Bi-clor product and just adjusted the FC higher.
    So I guess I have 2 questions- is it ok to swim with an elevated CYA and is it safe to swim with a FC of 10-15ppm?
    Thjanks for help in advance. I am driving myself crazy trying to lower the cya in a fiberglas pool. It hot here in LA and my pool water looks great and I really would like to be swimming.
    mbar's Avatar
    Ashland, PA
    Default Re: Can you swim with High CYA
    The higher the cya in your pool, the higher you have to keep your chlorine level - it won't hurt you. Here is the chart:
    Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
    => 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
    => 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
    => 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
    => 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
    => 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
    When you get your chlorine number high, the only thing that may happen is that your bathing suits may fade a little. It won't hurt you.
    Northeast PA
    I live near Shreveport, and my CYA stays 80-90 ppm (intentionally--my pool gets direct sun all day). I keep Cl level at 7-9 ppm all the time, and swimming is no problem.
    cajunfla is offline ** No working email address ** Thread Analyst cajunfla 0
    Jacksonville, Florida, USA.
    Other than draining and refilling, is there another way to lower CYA?
    It's the only practical way. The other way is to let your pool go really, really, really green and let the algae break it down. I'd rather drain/refill!
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 05:47 PM
  2. Trying to Swim More and do less work
    By szampino in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-11-2008, 12:23 PM
  3. High chlorine ok to swim?
    By no1ford in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-13-2006, 04:17 PM
