Results 1 to 10 of 20
Thread: Intex 20 x 12 x 48
    Lehigh Valley, PA
    Default Re: Intex 20 x 12 x 48
    Welcome to the forum!
    You'll need some stabilizer, also called cyanuric acid 100% or balancer. It helps keep the chlorine in the water and helps it work better. Are you filling from a well or from a municipal water supply?
    Jun 2012
    Ohio
    We will be filling from a municipal water supply. Should we test the water right after filling before adding any chemicals? Do we need to buy shock?
    Go ahead and test your fill water. You don't need to buy 'shock.' Shock is a verb, not a noun. Shocking just means super-chlorinating and you can just use bleach.
    Please fill out the Pool Chart with your pool's information.
    Pool Chart Entry Form
    Pool Chart Results
    Jun 2012
    Ohio
    We'll be filling the pool tomorrow. I read the post "Super Simple Pool Chemistry Recipe". It is extremely helpful! I do have a question, though. I ordered 100% cyanuric acid. Do I still need dichlor? Thanks so much for your help!
    If you use dichlor, you won't want to use the CYA. If you're going to use the CYA, then you should stick with just using bleach since it will add no CYA. Let us know which you want to do and someone will help you get started.
    Jun 2012
    Ohio
    Well, the plan was to fill the pool today. However, the inflatable ring is leaking air and we can't find where! I'm not sure if we should go ahead and fill, and hope that it will be easier to find the leak, or eat the $ spent on it (we bought it used) and purchase a new one. Right now I have about 2 inches of water in the pool. Should i add a dose of bleach to it until we decide what to do about the leak?
    Lehigh Valley, PA
    Oh how frustrating! By my calculations you have about 150 gallons in there. Give it 1/2 cup of bleach, that'll hold you for a couple of days.
