Oh how frustrating! By my calculations you have about 150 gallons in there. Give it 1/2 cup of bleach, that'll hold you for a couple of days.
If the pool had a hole in it when you bought it, then I think I'd make them give me another one.
They bought it used, WM. They might not have known of the leak when they bought it.
Good job on finding the leaks!!!
Have you seen this post from PoolDoc: http://www.poolforum.com/pf2/showthread.php?17055 . It's a wonderfully detailed description on how to start up an Intex or other small pool.
I did see that post~ awesome info! I am following that plan, however I will be using CYA and bleach instead of dichlor. Should I start adding the CYA as soon as the pool is full? Also, what is the best way to add the borax?
You will need approximately 40 oz of CYA to get within 30 - 50 ppm. Add 20 oz now using the sock method. Wait a week, test CYA, add more as needed.
You can broadcast borax over the surface or you can put it in the skimmer with the pump running or you can dump it in front of a return with the pump running. It dissolves very quickly. Some people get a mild cloudiness when they broadcast it. It doesn't last and isn't anything to worry about.
Thanks so much for your help! My kids and I looked over the entire ring and couldn't find where it was leaking from. My husband came home, looked it over, and found 3 holes! He patched them up and it looks to be holding air.
We'll fill to 6" tonight, I'll add 2 doses of bleach in then. Finish filling tomorrow. When should I add CYA and what dose?
We can't return the poolBought it from a garage sale from a couple who put it up for 2 summers, but said it was rarely used. We knew we were taking our chances.
