Thread: New Pool Owner
    Default Re: New Pool Owner
    You are right in not being concerned about the TA--it's not going to be an issue for you in this pool unless you have a high calcium reading.
    The tabs are stabilized, but I still am not sure about the granules--dichlor granules ARE stabilized, cal-hypo granules are not. Either way, you'll need to watch your stabilizer level (and I'm sorry to tell you , but strips are not going to be accurate enough to depend on) and raise your chlorine level as your CYA level rises (see the "best guess chlorine chart in my sig above for more explanation). Sounds like you just have something, maybe an algae bloom trying to happen, eating up the chlorine. I would shock the pool by bringing your chlorine up to 12-15 ppm and holding it there until you can test at night and again in the morning and not lose any chlorine in the meantime. Once you do that, you should be able to maintain some chlorine in your pool.
    Jun 2012
    Northern Ontario Canada
    Glad I can disregard one issue for now. lol
    I am pretty sure my granules aren't stabilized. I really had, and hopefully have, no intention on using them permanently as they are a bit of a pain in the behind to either be sure they dissolve or to make sure they don't touch the bottom of the pool. Too much hassle for a mom of 4 who works too.
    I do have some shock treatment stuff and had wondered if I should use it but wasn't sure as the pool had only been used once and we've only had it up a week and a half. So for the shock stuff, put it in in the evening, test the level, and then test again in the am to see how much I lost over night. And if I'm still off the chart with too much chlorine so to speak that's a good thing. Then wait till the level comes back down to the 1-3 ppm and in theory my tabs will keep me there going forward.
    And I will need to look at investing in a better testing method too.
    You need to give ingredients of the granules and also the 'shock treatment stuff' so we can better advise you.
