Results 1 to 10 of 33
Thread: Chlorine block-need recommendations
    Default Re: Chlorine block-need recommendations
    Quote Originally Posted by Jess6521 View Post
    I'm also realizing, as I read the bucket page again that this may not be for me. When we dosed with bleach we held chlorine overnight, but then lost it by noon. Sigh...what to do now.
    Add stabilizer
    OR
    Use dichlor to chlorinate.
    Dichlor is probably the easiest -- for every ppm of chlorine, you'll end up with not quite a ppm of stabilizer.. If you'll complete the pool chart form, I can figure doses for you:
    Pool Chart Entry Form
    Pool Chart Results
    Your two best dichlor options are probably here:
    24 lbs PoolBrand bagged shock @ Sams Club
    Kem-Tek Dichlor 22 lbs @ Amazon
    It's available elsewhere, but it's often diluted with 'goop'. And, depending on what the goop is, it can cause no end of problems. Kmart, Walmart and most pool stores are selling 'goop' versions of dichlor. The dichlor above is plain "sodium dichloro-isocyanurate dihydrate", 55.5% available chlorine.
    Jun 2012
    Maryland
    Ok I filled in the chart...this link actually worked for me. Let me know your thoughts, and thanks for your time!
    20'x40' Double roman 24K gal IG pool; Skimmer tabs; Sta-rite s7m120 cartridge filter; Hayward sp2015x20 pump; 24hrs; Taylor 2006 c; delivered via truck; summer: ; winter: ; ; PF:5
    Ok. You need the dichlor ASAP. Your pool is large enough, so that if you can get it at Sams Club, you may want the 50# bucket instead of the 24 1lb bags.
    Meanwhile, add 2 gallons of PLAIN 6% household bleach (4 ppm of chlorine) to your pool each evening. 1 gallon of *fresh* liquid chlorine is an OK replacement.
    Plain dichlor is hard to find locally, but stabilizer (cyanuric acid) is sometimes available. If you can find some, put 4 lbs or so in an old athletic sock, and put it in the skimmer. You do NOT want the CYA granules in the folds of your System 3 beast cartridge!
    List what chemicals you have on hand, if any, so we can see what you can go ahead and use up.
    Jun 2012
    Maryland
    We have an 8 lb bucket of uv pro shield I will add that tonight to the skimmers. Will get more bleach tomorrow also.
    . . . if it's not too late . . .
    Jun 2012
    Maryland
    Too late. I will go pull it out now. So we would use the dichlor instead?
    Wait, you said prior to put it in a sock in the skimmer that's what I did with the uv shield...wrong? Ordering dichlor today...
    If the DE was in a sock, it's fine.
    Jun 2012
    Maryland
    Phew ok
    Jun 2012
    Maryland
    Ok. I thought you meant in addition to the evening dose. We'll continue the evening doses.
