Results 1 to 10 of 33
Thread: Chlorine block-need recommendations
    Default Re: Chlorine block-need recommendations
    Ok. You need the dichlor ASAP. Your pool is large enough, so that if you can get it at Sams Club, you may want the 50# bucket instead of the 24 1lb bags.
    Meanwhile, add 2 gallons of PLAIN 6% household bleach (4 ppm of chlorine) to your pool each evening. 1 gallon of *fresh* liquid chlorine is an OK replacement.
    Plain dichlor is hard to find locally, but stabilizer (cyanuric acid) is sometimes available. If you can find some, put 4 lbs or so in an old athletic sock, and put it in the skimmer. You do NOT want the CYA granules in the folds of your System 3 beast cartridge!
    List what chemicals you have on hand, if any, so we can see what you can go ahead and use up.
    Jun 2012
    Maryland
    We have an 8 lb bucket of uv pro shield I will add that tonight to the skimmers. Will get more bleach tomorrow also.
    20'x40' Double roman 24K gal IG pool; Skimmer tabs; Sta-rite s7m120 cartridge filter; Hayward sp2015x20 pump; 24hrs; Taylor 2006 c; delivered via truck; summer: ; winter: ; ; PF:5
    . . . if it's not too late . . .
    Jun 2012
    Maryland
    Too late. I will go pull it out now. So we would use the dichlor instead?
    Wait, you said prior to put it in a sock in the skimmer that's what I did with the uv shield...wrong? Ordering dichlor today...
    If the DE was in a sock, it's fine.
    Jun 2012
    Maryland
    Phew ok
    Jun 2012
    Maryland
    Can we swim during the day if we are putting in bleach at night? Should we bleach nightly until we hold chlorine during the day? Also, how do I become a full member of the forum, is it a paid by year type thing? Mid love some insight on opening and closing the pool ourselves when the time comes. Thanks again for all of the help!
    Subscription link is in my signature.
    You can swim during the day so long as there is still SOME chlorine in the pool; if not, you need to add a small dose.
    Jun 2012
    Maryland
    Ok. I thought you meant in addition to the evening dose. We'll continue the evening doses.
