Results 1 to 8 of 8
Thread: Pool pump showing a high psi
    Jun 2012
    Florida
    Default Pool pump showing a high psi
    I recently moved into a house with a pool and everything was working fine. However, now the pool cleaner moves VERY slow and the pump psi is around 30. I have a Haywrd system with a cartridge. I have pulled out the cartridge and cleaned. When I clean I very thoroughly the system drops to about 18-20 psi but that only lasts about a day then it goes back to 30psi and moving across the pool bottom slowly. What can I do to get this system running properly? I have taken the cartridge to pinch a penny and they said that the cartridges fine and doesn't need to be replaced.
    Honesdale PA
    Default Re: Pool pump showing a high psi
    Is the pool cleaner a pressure side or suction side cleaner? If it's a suction side then we look at the cartridge itself. The simple fact that when you clean the cartridge the pressure drops seems to indicate you're trapping something. Just to check, try running the system without the cartridge and get a reference point pressure reading. My guess is it will be way below the 18 psi you mention after a cleaning. Just looking at a filter with the eye isn't going to show if you have really fine stuff packed in and this isn't coming out with a normal cleaning. You'll eventually have t get a new cartridge so you may just do tht now. If that doesn't solve the problem just put it on the shelf for future use. Are you battling an algae problem or some kind of a dirt problem? I've never dealt with cartridges so maybe someone else has other ideas.
    Quote Originally Posted by Wakkoguy View Post
    If your pool is clear, and your cartridge filter is going from 20 psi to 30 psi in 1 day, you DO need a new cartridge, unless you've put something weird into your pool water. If you will tell me your EXACT filter model and make, I'll try to find the correct Unicel or Filbur cartridge for you -- you only want an OEM cartridge (possibly MADE by Unicel) or one of those two brands. The worst that will happen is that you end up with an extra cartridge, which is not a bad thing.
    But, I'm betting you'll end up needing 2 cartridges, 1 to replace your existing cartridge, and 1 to soak -- so you CAN clean properly in the future.
    mas985's Avatar
    Pleasanton, CA
    My guess would be an algae bloom.
    Mark
    Jun 2012
    Florida
    How do you properly clean the filter?
    The water is clear (I shock it every other week). Do you think I need to purchase a new one? how much are they? Best place to get them? How often do you have to replace them?
    Quote Originally Posted by Poconos View Post
    Not sure - has a cleaner that sucks water to the system and runs it through a filter
    Clean them by:
    Spraying them off -- NO pressure washer; no scrubbing.
    Soak them in 4 gal water + 1lb TSP + 1/8 cup of bleach each time you change cartridges.
    When swapping, remove from tank; drain, rinse, drain again, rinse, drain again, rinse a 3rd time; install
    Rotate them regularly, with one cartridge always soaking. NEVER acid clean a cartridge unnecessarily; NEVER acid clean without using detergent (TSP) first.
    (I think it was Waterbear who wrote the above. I copied it and pasted it from some notes.)
    Also --- sounds like you have a suction side cleaner. Does it attach to the skimmer in some way?
    Jun 2012
    Florida
    I just got the new filter put in and the pressure is down from 30 to 10! Works great, thanks for the advice.
  1. No Chlorine showing up!!
    By Preston in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-28-2012, 07:13 PM
  2. Chlorine Not Showing Up...
    By tommypenngotti in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-01-2009, 05:20 PM
  3. CYA not showing yet.
    By les_smith in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2006, 11:16 AM
  4. Old Pool Pump--high electric bill
    By Metolius in forum Pool Equipment & Operations
    Last Post: 07-06-2006, 01:26 PM
  5. Still showing no cya
    By tjcat in forum DPD-FAS based testing
    Last Post: 07-02-2006, 05:41 PM
