Thread: Calcium Chloride Link to Cloudy Water??
    Fallon, NV
    Default Calcium Chloride Link to Cloudy Water??
    I'm wondering if anyone has experienced hazy/cloudy pool water after adding Calcium Chloride to increase Calcium Hardness. It seems like I had hazy/cloudy pool water a few years ago after adding Calcium Chloride, and now I have another, after adding Calcium Chloride. I wonder if there's a saturation point where adding to much, to fast, causes the water to become saturated with the stuff. It seems like a read that the plaster benefits from the additional Calcium (after all that's one ingredient in plaster) by absorbing it. If there's to much in the water, the plaster can't absorb it fast enough and the water becomes clouded with Calcium Chloride. I don't know, maybe I have an over active imagination. Thoughts are greatly appreciated.
    Scott,
    Downingtown, PA
    Default Re: Calcium Chloride Link to Cloudy Water??
    I added 15 #s of calcium chloride to an IG plaster pool at the beginning of this season. Within an hour the slight-haze was gone and the water was crystal clear. Not to say you are wrong, as my Ca level was very low, but just an FYI.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    Fallon, NV
    Interesting, maybe the reverse is true.... My Ca level is extremely low, just filled the pool a few days ago with soft water. I have added 8 lbs thus far, I'll add another 4 today and see where that takes it. Thanks
    Scott
    EricF is offline ** No working email address ** EricF 0
    Greenville, NC
    Please post your full test kit numbers, especially total alkalinity. Calcium chloride with high total alkalinity can definitely cause cloudy water.
    Eric F
    Mandeville, LA, USA.
    Here's 99 other reasons you might get cloudy water.
    http://www.poolsolutions.com/gd/cloudy.html
  1. Calcium chloride and sodium hydrogen carbonate
    By Rkh3 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-30-2011, 09:43 PM
  2. calcium hypo vs. calcium chloride
    By Oclat in forum Dealing with Alkalinity and Calcium
    Last Post: 06-04-2010, 05:06 PM
  3. Adding sodium bicarbonate AND calcium chloride at the same time
    By thr56 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-23-2006, 03:03 AM
  4. Swg And Water Softener With Potassiem Chloride
    By guild1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-16-2006, 11:27 PM
