Thread: How to point the jets
    Jul 2011
    garden city, ks
    Default How to point the jets
    Hello,
    I need some quick advice on how to point my two return eye jets on my 18 x 36 rectangular in ground pool. one is in the middle of the shallow end pointing south. The other jet is off to one side on the deep end pointing west. The deep end is 8 ft. I think I should point them straight ahead and have the return water slightly disturb the surface, right? This is for normal operation.
    Thank You
    Gary
    POOL SPECS: In-ground vinyl; 18 x 36' 24,000 Gallon,
    May 2010
    Default Re: How to point the jets
    I point mine just enought to break the water surface and create a current and circulate water around the pool
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    Normally I point my jets in such a way as to move the surface water towards my skimmers. I also have them just breaking the surface so the debris on the top of the water gets swept into the skimmers. Sometimes , when trying to stir up the water on the bottom of the pool, like during an algae bloom, I'll point the returns down a bit.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
    I pretty much do what TomC does. Plus, whenever I add bleach to the skimmer (which is the way I typically add mine), I aim my jet down so as to mix the bleach in better and faster and keep it from having hot spots of bleach aimed right at the side of my liner..
    Jul 2011
    garden city, ks
    Thanks for the replies!
    I think I read somewhere on here that if You break the surface too much, it carbonates the water a bit lowering the PH. I was having that problem, so I adjusted them like You all mentioned; just barely breaking the surface and aimed them to get a slight cyclonic action. I have only one skimmer, so have to adjust it so the speed isn't too slow or too fast so the leaves go right in; hopefully.
    Is is hard on the pump to add the chlorine to the skimmer? I have always just poured it in front of a return jet in the deep end.
    Thanks,
    Gary
    Pouring bleach slowly into the skimmer is fine, as is pouring it slowly in front of the return jet. Either way.
    If you aim your return jet upward to ripple the water, it will gradually raise the pH, not lower it.
  1. DE out the jets...
    By Muggi in forum Pool Equipment & Operations
    Last Post: 05-11-2012, 01:56 PM
  2. Brass deck jets versus Jandy deck jets
    By pumpkineater59 in forum Pool Equipment & Operations
    Last Post: 04-13-2012, 12:58 AM
  3. two of my jets have come out how do i fix them
    By danhuff11 in forum General Interest
    Last Post: 07-07-2011, 08:27 PM
  4. Magic pH break point?
    By steveinaz in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-04-2009, 12:42 PM
  5. Air/Bubbles from jets
    By LG1003 in forum Pool Equipment & Operations
    Last Post: 07-06-2007, 12:14 PM
