Results 1 to 9 of 9
Thread: Test Kit - is this OK?
    Default Re: Test Kit - is this OK?
    You CAN buy a kit just for FAS-DPD testing of chlorine. I think Ben sells one, and I think Leslie's web site sells one, but Taylor should sell one directly.
    As far as diluting 1:1 and multipling the results by 2...yes that is fine. You can even go as high as 4 parts water to one part pool water and multiply by 5. The more you dilute the less accurate your test becomes but it will be in the ballpark. In face, CarlD calls this his "shotglass method" beause he recommends a shotglass for measuring! Only change I would make to this is to wash the shotglass out afterward and use it to mix a nice drink to sip while floating in the pool
    jnorris is offline Registered+ Thread Analyst jnorris 0
    Florence, SC
    Quote Originally Posted by waterbear
    Yep, I am a "cold fruity drink with a kick" kind of girl!
    Judy
    S.E. Pa.
    I have finally figured out who Ben is (although I glean from the postings that it will take a while to get a test kit); but who is Leslie and Taylor, how can I find them to purchase a test kit in a hurry? What are their websites or contact info?
    Sanford, FL
    Leslie's is a large chain of pool stores. Taylor is a brand name of a test kit - which i believe you can buy from Leslies pool store.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    S.E. Pa.
    OIC, we must not have any Leslie's in this area as I have never heard of them before. I will search for a Taylor test kit. Thank you so much for setting me straight!
    CAPTCHEMCL: I received your private message and I forwarded it to Carl because he is more up on some of the kits than I am. He tried to reply to you, but your inbox is full. Delete some of the messages from your inbox and those you have sent and we'll try again tomorrow.
    EDIT: Saw on another thread that you ordered Ben's kit, so I guess you don't need the info on the kits on the Leslie's site anymore. Good decision. Ben's kit is the best one you can buy.
