Results 1 to 10 of 10
Thread: Weird Levels
Threaded View
    Mar 2012
    Tennessee
    Question Weird Levels
    As you can see from my previous posts we have been dealing with mustard algae. Ran out of reagents and were unable to test for 3 days. We continued to add 6% bleach until we got the reagents we ordered. Also added a box of borax since ph was 7.2 Tested at 6:30 pm tonight the levels were as follows:
    FC 25.5 CC 0 ph 7.2 Alk ?? CYA 40 Now the question. My CYA was running anywhere from 80 to 95 in all the previous tests. I tested twice tonight to make sure I did it correctly. Same results both times. The alkalinity never did turn red. Lost the green color after 8 drops. Did this test twice also, same results. After 20 drops, I stopped.
    By my calculations using the Pool Calculator I should add 9.8 (10) jugs of 182oz. 6% bleach. Can I add another box of borax or should I wait? We still have 10-12 small dime size brown spots in the bottom of the pool but the water is clear.
    Found polyquat 60% at the local pool store. Once this mess is cleaned up do you recommend? I definately do not want this to come back. I have the Taylor K-2006 teting kit. For chlorine the reagent is R-0871. The 2oz R0871-C is the same correct? Just a bigger bottle? Thanks in advance for all of your help.
    Chlorine level after 2 hours is 60- after 10 jugs of bleach.
    Lynn
    1 1/2hp Emerson 2speed pump, BBB
    27' round 19.3K gal AG Vinyl Liner pool; sand filter; pump: 24 hrs on low; Taylor K-2006 FAS-DPD Chlorine; utility water ; PF:6.9
