Results 1 to 10 of 10
Thread: Weird Levels
    Mar 2012
    Tennessee
    Question Weird Levels
    As you can see from my previous posts we have been dealing with mustard algae. Ran out of reagents and were unable to test for 3 days. We continued to add 6% bleach until we got the reagents we ordered. Also added a box of borax since ph was 7.2 Tested at 6:30 pm tonight the levels were as follows:
    FC 25.5 CC 0 ph 7.2 Alk ?? CYA 40 Now the question. My CYA was running anywhere from 80 to 95 in all the previous tests. I tested twice tonight to make sure I did it correctly. Same results both times. The alkalinity never did turn red. Lost the green color after 8 drops. Did this test twice also, same results. After 20 drops, I stopped.
    By my calculations using the Pool Calculator I should add 9.8 (10) jugs of 182oz. 6% bleach. Can I add another box of borax or should I wait? We still have 10-12 small dime size brown spots in the bottom of the pool but the water is clear.
    Found polyquat 60% at the local pool store. Once this mess is cleaned up do you recommend? I definately do not want this to come back. I have the Taylor K-2006 teting kit. For chlorine the reagent is R-0871. The 2oz R0871-C is the same correct? Just a bigger bottle? Thanks in advance for all of your help.
    Chlorine level after 2 hours is 60- after 10 jugs of bleach.
    Lynn
    1 1/2hp Emerson 2speed pump, BBB
    27' round 19.3K gal AG Vinyl Liner pool; sand filter; pump: 24 hrs on low; Taylor K-2006 FAS-DPD Chlorine; utility water ; PF:6.9
    Mar 2012
    Tennessee
    Default Re: Weird Levels
    Help! I really need to know why/how my cya level has dropped and why alk test does not turn red. Levels are as follows today: FC 29 CC 0 ph 7.2 alk ? turned orangish at 75 (same results when I used the 10ml instructions in the test kit) cya 35-40 CYA was 80-90 a week ago I tested twice last night and twice tonight and it was the same. Regarding the Taylor K-2006 test kit. Is the only differece in the R0871 and the R0871C just the size? These questions may seem silly to some but I will get the hang of this. On the bright side, have not seen any more "brownish/yellow dust". Makes us VERY happy pool owners. One last question. Since we had the problem with mustard algae do you recommend the polyquat be used or not? We are undecided on it.
    Sorry you haven't gotten responses to this yet--I've spent quite a bit of time on the forum in the last few days and this is the first time I've seen this post--don't know why. Anyway...
    The only difference in the R 0871 and r0871c is the size of the bottle.
    I'm not sure why your alk doesn't turn red--but I would count the drops until you get the last permanent color change and call it that level. Regarding CYA, other than biodegration by algae or some bacteria, the only explanation that I could offer for lowering CYA is replacement of water--either splashout, large amount of vac'ing to waste, or backwashing the filter. You can backwash out an immense amount of water with a sand filter.
    Regarding the polyquat, I don't use it in my pool, but also have never had to conquer mustard algae either. My guess would be that it would be a good thing to use as a secondary defense to chlorine, but I'll let Pooldoc, Waterbear, chem geek, or some of the others chime in with a more informed opinion.
    When the chlorine level is very high, the TA test goes from blue to yellow instead of green to red. You might be be confusing the initial blue as thinking it's green or perhaps it's an in between color, but going to yellow makes it look sort of clear. That sounds like what is happening. As for the CYA level, I don't have an explanation for that but I wouldn't worry about it. You'll know if the CYA is really that low because you'll notice higher chlorine loss during the day and after things settle down you can test again if you want.
    As for yellow/mustard algae, you really need to get completely rid of it including behind light niches and under removable ladders where it likes to hide out in shade. Also, all pool equipment that contacts the pool water needs to get into the pool. If you want extra protection, you can either 1) keep the FC at a minimum of 15% of the CYA level (though that obviously can become impractical) or 2) use Polyquat 60 weekly or 3) use 50 ppm Borates in the pool. Though I believe the Polyquat may help, I'm not sure about the Borates for yellow/mustard algae -- I know it helps with green algae).
    Mar 2012
    Tennessee
    Levels today at 11:00 am : FC 15 CC 0 ph 7.6 ALK 90 CYA less than 30. Last night I added sodium carbonate to raise the ph. I know it can raise alk but as we were at 80, felt it would be ok. Will be going today to get more borax. What do I need to do to raise the CYA levels? Or should I let it be and use the triclor pucks that I have when the chlorine level comes down a little more? Can you swim with the FC at 15 without turning highlighted hair green? Water is clear with no signs of the mustard algae or brown dusty spots. Have soaked EVERYTHING that goes in the pool in bleach. Thanks to everyone that helped us get rid of the mess. Couldn't have done it with out you.
    You can just use your pucks to add chlorine and CYA for awhile and then when your CYA hits about 50, discontinue their use and switch to bleach. (But, read the label on the pucks and make sure they are only trichlor. Some have other things like copper in them and you do NOT want copper in there!)
    Contrary to popular belief, it is copper that turns blonde hair green and not chlorine. You can swim with chlorine at 15ppm. I won't hurt people but I wouldn't wear my good swimsuit. Take a look at the Best Guess Chlorine Chart in Janet's signature above.
    pH at 7.6 is about perfect so don't add any Borax at this point. If you do decide to use the pucks, watch your pH. The pucks are very acidic and will drive the pH down.
