Re: Weird Levels
Levels today at 11:00 am : FC 15 CC 0 ph 7.6 ALK 90 CYA less than 30. Last night I added sodium carbonate to raise the ph. I know it can raise alk but as we were at 80, felt it would be ok. Will be going today to get more borax. What do I need to do to raise the CYA levels? Or should I let it be and use the triclor pucks that I have when the chlorine level comes down a little more? Can you swim with the FC at 15 without turning highlighted hair green? Water is clear with no signs of the mustard algae or brown dusty spots. Have soaked EVERYTHING that goes in the pool in bleach. Thanks to everyone that helped us get rid of the mess. Couldn't have done it with out you.
1 1/2hp Emerson 2speed pump, BBB
27' round 19.3K gal AG Vinyl Liner pool; sand filter; pump: 24 hrs on low; Taylor K-2006 FAS-DPD Chlorine; utility water ; PF:6.9
