Results 1 to 10 of 28
Thread: New Intex Easy Set 15' x 48" owner - first time pool guy
    Default Re: New Intex Easy Set 15' x 48" owner - first time pool guy
    No. It just takes time. There are currently about 31 threads that need moved. Ben is stretched pretty thin. In addition to getting the never-ending stream of registrations completed (and just as soon as he empties out this getting started section, it fills right back up), he also is busy answering posts, writing various guides such as the one he posted yesterday about intex pools, and maintaining some local pools where he lives. Plus, being a dad and a husband! So, his plate is pretty full, but never fear, he'll get your registration finished and your post moved just as soon as possible.
    One other comment ----- Ben, the mods and the Pool Forum Support Team are the ones who can see this section of the forum, so the ones who have pool experience are already able to see your post here anyways!
    Hope you enjoy being a part of the forum!
    Jun 2012
    Long Island, NY
    Sounds good, thanks for the reply.
    FYI - The pool was just delivered! On the way home from work I'll pickup the bleach and borax.
    BigDave's Avatar
    Thumbs up Re: New Intex Easy Set 15' x 48" owner - first time pool guy
    Great planning!
    You already know this but I'll say it - Level, very level, measured level. I can tell you from experience (had to drain and rebuild / refill our first donut pool) that "looks level" and "I'm sure it's level" and "is level" are different.
    I think dichlor is a great way to start your pool. A total of 3lbs will get you to the 50ppm range - all you probably want. A total of 2lbs should get you to around 30ppm - OK if your pool has plenty of shade. Don't add that much at once, follow the dosage guide. You can dissolve it in a bucket of water before adding it to the pool then stir up the pool if the pump's not on yet. Adding it to the skimmer is not an option with your filter.
    The dichlor will push the pH down so have Borax on hand to bring it up.
    Since you'll have the k-2006, you can dose based on what your pool has used rather than daily and swim sessions. Test chlorine and pH often (several times a day) at the beginning as the sun will burn through your FC quick with very little CYA. Make sure you stay above the minimum FC level on Ben's Best Guess Chart at all times.
    There are only a few CYA tests in the kit so do that one sparingly. If you keep track, you can move to the second band of Ben's Best Guess Chart after the first 3/4lb of dichlor and to the third after the first 2lbs total dichlor.
    That pump may be OK but stay ahead of your water. It's real hard to clean up algae with one of those. Personally, I don't trust the electrical isolation in these pumps and I didn't allow anyone in or around the pool when it was plugged in. I ran the little pumps 24/7 when no one was in the pool.
    The Skooba Vac looks pretty neat. I bought a AG robot cleaner during the first summer of our first donut pool (we are surrounded by trees) and have been very happy. It also helps to filter the pool as the intex type filters are pretty weak.
    Good Luck, You're gonna have a great time!
    Jun 2012
    Long Island, NY
    Well I have to stop spending money, but this was a good deal. And after reading about how crap the cartidge filter is I snagged the 1600 sand filter for $137.99 w/free shipping off Amazon. It shows as 189.99 but if you look to the right there is a seller offering it for 137 w/the free shipping. http://www.amazon.com/gp/product/B00...sr=8-1&seller=
    Wow, I just wish everybody that was putting in a pool would be as thorough with the research and learning as you have been.....you shouldn't have any problem at all with your pool, but if you do, just know we're here to help!!
    Good job!
    Jun 2012
    Long Island, NY
    Just a quick update... That deal turned out to be to good to be true... I get an email from Amazon stating 4-6 weeks delay in delivery due to backorder. I canceled the B/O and went with the 2650 which I figured could be used for when I get a bigger pool. Perhaps way, way overkill for what I need (which could be good, I can run the filter less hours?). Total cost was ~197 with free shipping. Now with this size filter / pump setup how many hours a day should I run it?
    BigDave's Avatar
    I'd seriously consider buying better cartridges for your new filter and setting up a cleaning regimin. See Ben's post #7 in this thread for detailed steps. If your new filter uses size B carts, you can find better quality carts here:
    Unicel C-5315 Replacement Filter Cartridge for 15 Square Foot Intex B Filter @ Amazon
    Jun 2012
    Long Island, NY
    No need for the cartridges any more, the sand filter is on the way
