Thanks.
Question for the engineers/scientists: Wouldn't a main drain suction blockage at 6' underwater, and a pump surface side 2' above cause the pump to pull oxygen from the water.
My thinking is since water contains O2, that any blockage in the main drain would restrict flow, causing the pump to work at the same rate, yet pull O2 from the water at a faster rate than it actually sucks the water.
Make sense?
