Results 1 to 10 of 41
Thread: Newbie with MAJOR problem...
Threaded View
  1. #13
    JJ in Tx is offline ** No working email address ** JJ in Tx 0
    Spring, Texas
    Default Re: Newbie with MAJOR problem...
    Never tried but was figuring that the "power" was all coming in thru the air hose and everything happening on/at chisel was exhaust from the operation. would make sure i oiled tool prior to and after use as well as run it a bit once it was out of the water to make sure it was "dry" before storing it.
    JJ
  1. A MAJOR problem
    By SL Dan in forum Dealing with Algae & Slime
    Last Post: 09-01-2011, 05:53 PM
  2. Major Chemistry Problem on open
    By psciotti in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-24-2011, 12:05 AM
  3. Newbie - old concrete pool problem
    By eville in forum In-Ground Pool Construction and Repair
    Last Post: 05-12-2010, 07:28 AM
  4. newbie with pool... pressure problem.
    By lange in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 06:29 PM
  5. Newbie with filter problem
    By South_paw in forum Pool Equipment & Operations
    Last Post: 03-31-2006, 10:08 PM
