Closed Thread
Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 41
Thread: Newbie with MAJOR problem...
  1. #31
    Default Re: Newbie with MAJOR problem...
    Why use a hose? What does that accomplish? Please explain.
  2. #32
    Hanford,CA
    What he's talking about is basically sleeving the existing pipe by running the hose through the inside of it. The tricky part would be sealing it at both ends so that water does not leak back along the outside of the Hose/Tubing and out the original leak. I would think that the loss of volume and added restriction would not make this a very good alternative.
  3. #33
    What does the hose accomplish? Please explain!
  4. #34
    Hanford,CA
    The hose does not have a leak in it. Your existing underground pipe you are running it through does. You would push /pull the hose through the entire length of your pipe then the hose would be sealed to the pipe at both ends and essentially becomes a new pipe, eliminating the leak. The problem is that in order for the hose to fit inside the existing pipe it must be a smaller diameter, this would restrict flow and total volume.
  5. #35
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    Correct, The hose would replace the inside of the pipes.
    Not as good as replacing the pipes but it's a lot cheaper than digging them up.
    Sealing both ends should be fairly straight forward with proper fittings. I'll post any pictures when I get it finished.
    Yes, it would be smaller diameter but it wouldnt leak
    In my case the smaller diameter hose is an acceptable alternative. If anyone has a better Idea or reason not to try this I'm all ears.
  6. #36
    Quote Originally Posted by MyBlueDog
    Hey Waste (and everyone),
    Thanks for the advice. You said if I need help to write. So I am.
    Now that I believe I've found the leak, and there's a temp. plug I placed in the skimmer, should I call out a leak detection service to pin point the thing...?
    My goal is to try to keep my pool holding water. Mainly so I can use my skimmer.
    My pool is screened, so I've never really used the skimmer since most of the debris stays out. I use my main drain, cuz I've been forced to. But more importantly, it's never held water. So I want the thing will hold water permanently!!!!
    I'd rather not abandon the skimmer entirely by permanently plugging the skimmer hole until I determine fixing the thing may be either too costly or labor intensive. Know what I mean?
    I am seriously thinking of buying some of that liquid leak sealer and following the instructions for 29 bucks and dumping that into the skimmer to see if it plugs it up.
    Where would you start next? A leak company??
    Ideas and advice, please.
    Thanks,
    Daryl Bluedog
    Florida
    Daryl, how to proceed depends on what you can afford vs. how badly you want the repair made and how quickly you want it made. For the most part, pool repairs are done on a 'time and materials' basis, you pay an hourly rate for the guys to come out and diagnose and make the repair + the cost of the materials they have to use to perform the fix. When your talking about having to dig under a deck to get to the problem, the price can skyrocket, just in digging time. There are some things you can do to lessen the time they are there, if you'd like me to fill you in on them, I will, gladly (however, no guarantees on 'workability' for your particular situation). If you want the skimmer for next weekend and can afford it, call in your local experts, it'll be one less thing on your mind. As per before, if I can be of any help, I will do all I can for you - Ted (a/k/a/ -WASTE)
  7. #37
    Hi Ted,
    So.... what do you recommend?
    a. Try the 29 dollar quick sealer and run it through the skimmer to see if that solves the leak?
    b. Call in a leak company to confirm what I know -- the skimmer is leaking somewhere below the skimmer line, and to pinpoint the leak.
    Permanently fill my skimmer with concrete?
    What??
    Daryl
  8. #38
    Dayrl, I can't see how a $29 product could fix the leak, if you put it in with the system running, the air being drawn into the line would keep the sealant from getting where it needs to be, without the system running it could cause the same thing to your skimmer line that the concrete did to your MD. I'm thinking that getting the leak guys in there to let you know ~exactly where the problem is (again... IF THE COST OF HIRING THEM IS WORTH HAVING THE SKIMMER USEABLE) Depending on what they find, you may be able to fix it yourself or you may have to call in a pool company (but even if you have to 'call in the pros', you might be able to save some $ by doing some of the work yourself). If you decide to try the $29 fixit, don't let it in your filter, by it's nature that stuff will kill the filter. Wish I could check it out in person, but the next time I see Fla. will be out the window of the airplane when I go to the Bahamas in '08 - Good luck, keep us informed -- Ted
  9. #39
    **UPDATE EVERYONE
    I have determined that I have two separate things going on.
    1. My 2" main drain is 50% blocked by concrete, left over from a resurfacing job done in 1992. Tihis is causing restricted water flow, and cavitation in my pump. (top 1/8 of my pump is continual air)
    2. My skimmer line is broken, somewhere underground, anywhere from the bucket to the pump. (This is causing my water loss.)
    I am hiring a reputable leak guy for $150 to pressure test the skimmer line and find the link using compressed air and the electro-detection.
    So I've got two pretty good problems to contend with. To me, the most important is keeping water in the pool.
    I'll keep working at the main drain crete using a screwdrive and dive tanks. My red knuckles, even with dive gloves, thank you.
    D.L.
  10. #40
    ** PROBLEM(s) ISOLATED & LESSONS FOR EVERYONE
    According to a local, reputable leak detection service, and the owner of that company who I know has done over 1,000 leak detections in the past 2 years, I have two (2) completely separate issues occuring with my in-ground pool.
    1. Main drain 60% blocked with concrete and cause cavitation in pump, return bubbles into pool, a loud, noisy pump, and top 1/8 of pump lid to have air in it.
    Cause: Shoddy construction 20 years ago, confirmed by previous pool owner.
    Lessons Learned
    a. Do as much as you can on your own... but know when to fork out cash to get an expert.
    In my case, the leak detection cost me $150, and the company found what was happening in less than 45 minutes.
    b. Attempt to contact the previous owner of your pool.
    In my case, my neighbor told me the name of the people who built the pool. Since they were NOT the previous owner I bought the house from, I looked them up in the phone book. I got lucky and they still live in my town. I called him, and he was very nice and said he had all kinds of problems with the pool contractor. So much so he never paid them (until they filed a lien against him.) His words to me, "I am not at all surprised you found concrete in the main drain.
    2. Skimmer is broken at or near top 90 PVC fitting.
    a. Leak company found this via pressure test. To double cjeck, they even drilled a pilot hole into my pool deck next to the skimmer, inserted a rod about 12 inches through the concrete into the soil. It was soaking wet.
    Lessons Learned
    Whenever you suspect a leak, start plugging holes! In my case, I plugged the skimmer and the leak stopped. This helped the leak company save time and isolate the problem, and only cost me $150 (vs. many other services that charge 300-$500).
    What's Next? What Are The Costs?
    1. Continue very gently to pick at the concrete in my main drain using a screwdriver and my dive tanks. Or leave it alone. (Cost: Free, just my time and air refills. Note: Leak company won't touch this, due to concerns about harming main drain.)
    Once I get my skimmer repaired (below) I can abandon the main drain, if I want.
    2. Cut out my skimmer and replace/repair it. This will involve cutting the deck around the skimmer, approximately 2x2', with a concrete saw, jackhammering the concrete, and getting underneath approximately 12-18" below the deck to attempt to make the repair. No... I'm not fooling with this. Cost: $700-$1,500. Repair/replacement is guaranteed by the leak repair company.
    While I could use the $700-$1,500 elsewhere, that's for sure, it's worth making the repair for the long-haul and not fooling around with this.
Closed Thread
  1. A MAJOR problem
    By SL Dan in forum Dealing with Algae & Slime
    Last Post: 09-01-2011, 05:53 PM
  2. Major Chemistry Problem on open
    By psciotti in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-24-2011, 12:05 AM
  3. Newbie - old concrete pool problem
    By eville in forum In-Ground Pool Construction and Repair
    Last Post: 05-12-2010, 07:28 AM
  4. newbie with pool... pressure problem.
    By lange in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 06:29 PM
  5. Newbie with filter problem
    By South_paw in forum Pool Equipment & Operations
    Last Post: 03-31-2006, 10:08 PM
