Results 1 to 10 of 14
Thread: Salt Water Generator / Intex Pool Question/advice
    Jun 2012
    Indiana
    Default Re: Salt Water Generator / Intex Pool Question/advice
    PoolDoc, my bad. Amazing the difference in a couple of letters: chloride, chlorine, nitrate, nitrite, etc. You are right to scold me for not being accurate
    It is amazing the paranoia the government, and in particular the yahoos in the EPA cause. As a scientist I am skeptical of anything coming from the EPA, the Center for Science in the public, and similar NGO that don't have any relevant data to back up their claims. Often they will cite some obscure study in the hinderlands of France with a maximum of 100 subjects, and then claim the 300 + billion people on the earth will be similarly affected. (Sorry for the soapbox).
    Thanks for the advice. Will get to the shocking. Also, should I continue to increase the CYA. The pool place has a broad range of 30-150 ppm. Is higher better in this case?
    Aylad,
    Good point, although I am less concerned with the viruses as opposed to water borne bacteria. The cells of virus are more susceptible to disinfectants, even low levels and are incapable of reproducing without a host. Bacteria commonly grow in water environments (e.g biofilms that are at water fountains, in water coolers, etc.). Nonetheless, still good points.
    Thanks again for all the advice. I have some work to do to get this stabilized.
    Rob
    Quote Originally Posted by Indywar View Post
    As far as we know, the high risk events in pools are all related to person-to-person transmission, usually fecal-pool-oral or snot/spit-pool-oral. And, the culprits are usually either viruses OR amoebic oocysts. The data I've seen suggests that pathogenic viruses are MORE, not less, resistant to chlorine. Also, though these cases are not biofilm related, they ARE fomite related, and killing fomite associated pathogens is a LOT harder than killing planktonic pathogens!
    There some common low risk events, associated with P. aeruginois and biofilms (hot tub itch; otitis externa) but those don't kill anyone or even make them very sick.
    One rare exception: Naegleri fowleri is VERY dangerous and can actually live in pools, apparently.
    Right now, the pool is the problem -- but this fall, if you are interested, it would be very helpful to have a working microbiologist looking over my shoulder as I'm putting SwimmingPoolResearch.com together. I've got about 8 Gigabytes of peer-reviewed articles to index!
    Oh, and you're preaching to the choir, at least with me, about trusting "scientists" and especially government "scientists". Here something my older son (a recent biochem grad) found for me:
    "It has long been known"... I didn't look up the original reference.
    "A definite trend is evident"... These data are practically meaningless.
    "While it has not been possible to provide definite answers to the questions"... An unsuccessful experiment, but I still hope to get it published.
    "Three of the samples were chosen for detailed study"... The other results didn't make any sense.
    "Typical results are shown"... This is the prettiest graph.
    "These results will be in a subsequent report"... I might get around to this sometime, if pushed/funded.
    "In my experience"... once.
    "In case after case"... twice.
    "In a series of cases"... thrice.
    "It is believed that"... I think.
    "It is generally believed that"... A couple of others think so, too.
    "Correct within an order of magnitude"... Wrong.
    "According to statistical analysis"... Rumor has it.
    "A statistically oriented projection of the significance of these findings"... A wild guess.
    "A careful analysis of obtainable data"... Three pages of notes were obliterated when I knocked over a glass of pop.
    "It is clear that much additional work will be required before a complete understanding of this phenomenon occurs"... I don't understand it.
    "After additional study by my colleagues"... They don't understand it either.
    "Thanks are due to Joe Blotz for assistance with the experiment and to Cindy Adams for valuable discussions"... Mr. Blotz did the work and Ms. Adams explained to me what it meant.
    "A highly significant area for exploratory study"... A totally useless topic selected by my committee.
    "It is hoped that this study will stimulate further investigation in this field"... I quit.
    Jun 2012
    Indiana
    Hi Ben,
    Sorry for not replying sooner, but my computer crashed, yet again. Let me know when you need a hand with the micro stuff, and I would be glad to help. I have followed the advice that has been given here and think the pool is finally stabilizing. I had reverted to bleach and shock to keep the chlorine levels higher, especially with this hot days and higher use. It seem the pH and chlorine have both settled into a normal expected range. Thanks to everyone on the forum for the troubleshooting advice and assistance.
    Rob
    Glad things are working out for your pool.
    If your computer problems are related to security, you may want to read this article sooner, rather than later:
    http://news.discovery.com/tech/dns-c...ay-120426.html
    I'm expecting to 'lose' quite a few PoolForum members that day!
    I'll flag your member record as being a biologist, and will try to get in contact once things slow down a bit.
    Jun 2012
    Indiana
    Thanks for the heads up. I read that on Drudge this morning too. I will need to check my PCs this evening. I plan to start cloning my primary hard drive on a separate drive, in case this crash happens again. That way I can pop the cloned drive right in and never miss a beat.
    Which reminds me of a funny story: We sat next to the virologist group until recently and they had printed a picture of an electron micrograph of a retrovirus. One day they posted it on there cube wall with the type of virus. An IT guy walked by, looked at it and commented that he always wondered what those computer viruses looked like. We thought he was joking initially, but he just walked away, so I think he was serious.
  1. Salt water generator
    By kmac1196 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2012, 10:36 AM
  2. Replies: 8
    Last Post: 04-09-2012, 05:37 PM
  3. Need Advice on Salt Water Generator purchase & conversion
    By mickey4paws in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 03-22-2009, 08:31 PM
  4. salt water generator
    By clhealy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-15-2006, 04:03 AM
