Thread: small intex 2,000 gallon above ground
    Jun 2012
    western north carolina
    Default small intex 2,000 gallon above ground
    when we opened the pool this year (3rd yr) we have floating gobs of white mucous. we have vacuumed and skimmed every day, tested and balanced the chemicals.(yes with a guess strip but after reading your forum we're getting a better test kit tonight) it's a little better. i am hoping we won't have to drain it. please help??
    Default Re: small intex 2,000 gallon above ground
    Is this a chlorine, or Bacquacil pool? If you'll post a set of tests taken with a drop-based kit (we really recommend the K-2006, or at the very least, the hth 6-way drop test from WalMart) we'll be glad to help. While you're at it, please take about 30 seconds to fill out this form with your pool's info so that we don't waste a lot of time asking questions to try to get the info we need...
    Pool Chart Entry Form
    Pool Chart Results
    Everything that I know of, that causes anything like
    in a pool, is a pain to clean up. Unless you are on restricted water supply, or paying HUGE amounts for water, with a 2,000 gallon pool, it would be MUCH easier to drain and refill, than to try to clean it up.
    Read the sticky in this Intex section on Intex start up, and do NOT refill, till you are ready to go!
  1. New member w/ small Intex pool, looking at salt systems
    By Air_Cooled_Nut in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-21-2013, 07:53 AM
  2. intex small 8' x30"
    By flprobsolver in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-10-2012, 06:53 PM
  3. Newbie tips for a small above ground pool
    By svendster in forum Pool Equipment & Operations
    Last Post: 08-18-2011, 03:51 PM
  4. Help with filter selection for in-ground 35,000 gallon pool
    By rshady in forum Pool Equipment & Operations
    Last Post: 06-02-2011, 03:50 PM
  5. Have a small above ground pool, please help
    By rastoma in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-19-2006, 12:30 AM
