Results 1 to 10 of 29
Thread: cloudy water
    Default Re: cloudy water
    Even though it's late in the process, I think it would be okay to go ahead and add the Polyquat and sequestering agent. The worst case scenario is that you may have to use the ascorbic acid again, but at least now you know what order to use them in. Just watch your chlorine, because as Marie said, the acid will use a lot of it up, as will the Polyquat. Be prepared to add low amounts of chlorine to make sure there is "some", but not "a lot" of chlorine in your pool.
    I know balancing metals and chlorine is tricky, but mbar is the resident expert (besides Pooldoc) on metals around the forum, so if you'll stick with her advice, she'll get you on the right track
    Absolutely right!
    mbar's Avatar
    Ashland, PA
    aaw shucks
    Northeast PA
    mrszaff is offline Registered+ Thread Analyst mrszaff 0
    May 2010
    New York
    I appreciate everyone's input, thank you!
    I added the sequestering agent and polyquot around noon. at 8pm I added a gallon of bleach because my Cl was < 2 and will prob drop .
    I just took a reading and FC 7 cc 1 ph 7.2 alk 70 cya 50 I will check it in the AM again.
    The deep end is still cloudy, I cannot see drain. I have filter on 24/7.
    When I checked the baskets to remove insects, I noticed there is a green film gathering and green bubbles. I do not notice this on the pools surface though. Is this a sign that the algacide is working?
    16x32' rectangle 19K gal IG vinyl pool; bbb; jacuzzi sand filter; jacuzzi pump; 8hrs; Taylor 2000; utility water; summer: none; winter: vinyl / water bags; ; PF:6.3
    mbar's Avatar
    Ashland, PA
    I am not sure what was in your skimmer basket. What kind of algecde did you use? Some algaecides can cause some bubbles. I will be interested to see how much chlorine you lose overnight.
    Northeast PA
    May 2010
    New York
    We are in the middle of a of a major thunderstorm right now, the pool is filled to capacity so I dont know how this affects the water reading. I lost all the Cl according to my test , FC abd CC are less than 1. I had to turn off the filter because of the overflow.
    when it stops raining, and the lightening stops I will backwash and drain the pool back down to the right level. As far as I can tell it its still cloudy.
    what next?
    May 2010
    New York
    I backwashed and a lot of green came out and I brushed the walls and pushed everything to the deep end before I drained the water to the correct level. I also added 2 gallons of bleach. No more green slime in the baskets today. I used Leslies brand poly 60 algacide yesterday. I ordered the one you recommended from amazon but it will not be here till friday as well as sequestering agent and ascorbic acid so that I have it for the season.
    The deep end is still cloudy but also green today. Rain has stopped. I will take another reading around dinner time I guess.
    Any ideas?
    May 2010
    New York
    Here are my 5pm numbers I am totally obsessing and I apologize but Im on vavation today and I could cry about this pool...
    FC 4.4
    CC .2
    PH 7.4 (might be 7.5 hard to tell)
    Alk 80
    cya 45 (lowest I can remember it being in years..) pool is still not clear
    I can almost see the drain I think but its murky and tinted green in deep end, low end looks hazy
    I also have a curalator bag in basket for the last 2 weeks. I dont know if its helping still hasnt turned a color
    thanks, very frustrated....
