Re: Advice Needed - High CYA, High Nitrates, and Lots of Algae
capshockeyfan
(Hopefully it is okay to not add all of the bleach at once.)
Nope, Won't do the job. It ALL has to be added at once, the water retested, and more added as it is consumed to maintain the chlorine level at 25 ppm or greater.
A Taylor K-2006 will make things much easier for your. The kits from Walmart are just an inexpensive stopgap measure unti you get a good kit which will have to be ordered on the internet most likely.
