Results 11 to 14 of 14
Thread: Pool green 15,000 gallons
    Default Re: Pool green 15,000 gallons
    It doesn't have to be Clorox. Most of us use generic Walmart bleach.
    Ontario.
    Quote Originally Posted by biggun View Post
    Ok thanks. I will keep adding clorox daily till it clears.
    Yup, it isn't elegant, basically keep hammering the algae with chlorine until it clears up :-)
    I opened very late this summer and my pool was dark green, couple types of water bugs, thriving ecoculture. I ran it up to and kept it at around 20 ppm and it was clear in 3 days. The only adjustment I made was to bring down my PH level as it was high. I balanced my water after the water was clear and chlorine levels down to normal levels.
    IG 32' x 16', vinyl 19,500 l, Sand filter, Hawyard Low NOx 250,000 btu heater
    Heating? Great info on why a solar cover saves $$$?
    http://energy.gov/energysaver/articl...ng-pool-covers
    Jul 2012
    New York
    I thought I shouldnt add anything until the metal magic had been in there 12 hours.
    This is what my pool water looks like. I have no kit yet, so I went to the Dollar store and stocked up on 8 gallons of 6% bleach. Dumped 2 in at dusk and can't wait to see what happens.
    Also keep your pump and filter running 24/7, cleaning the cartridge as your pressure indicates. Many times, the cloudiness is due to dead algae that just needs to be filtered out.
    How's it looking now?
  1. BBB for small pool (6423 gallons)
    By sally1019 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-05-2011, 10:43 AM
  2. 8 gallons of bleach...still green!!!
    By Andersonian in forum Dealing with Algae & Slime
    Last Post: 07-03-2010, 12:01 PM
  3. How to determine how many gallons in pool?
    By cruzmisl in forum Above-Ground Pool Construction & Repair
    Last Post: 07-19-2006, 10:20 PM
  4. How many gallons is my pool?
    By shadowman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2006, 01:18 PM
  5. How to figure gallons in pool?
    By Poolidiot in forum Above-Ground Pool Construction & Repair
    Last Post: 05-16-2006, 07:21 PM
