Thread: Introducing myself & my pool/asking advice for automatic pool cleaner to buy
    Default Re: Introducing myself & my pool/asking advice for automatic pool cleaner to buy
    Quote Originally Posted by gracelover View Post
    I particularly want one that does microfiltration and can pick up dead algae. We have no main drain so one that can stay in the pool and come on several times a week would be great, for recirculation.
    That requirement is going to focus you on cleaners with built-in pumps and filters. Not sure you want to do that. In most parts of Alabama, you're going to end up with a fair amount of grass and leaf debris in the pool, and the robot-vacs don't do so well with those.
    A better plan might be to focus on a decent powered vacuum that collects debris, AND learning to operate your pool without algae.
    May 2012
    Canada
    Happy with my Hayward RC9730BL. Easy to clean. Good phone support.
    Jun 2012
    alabama
    Oh, a pool without algae is a dream at this point. After the liner was installed, the pool guys put our drop in steps back in (they weren't supposed to because the sand bags had not been cleaned yet, although the steps had. We had a liner failure along with a massive pool leak in the return line and our pool was a frog hole for about two months before the work started.
    When the weather warmed up the algae took off. We got it knocked down and then it started growing in the open area under the steps again. When I brushed, a green tide went all over the pool.. We had another clog in a line last week, and the pool guy told us it is yellow algae. So it is back to the drawing board for us.
    The bottom of the pool was clean - not now. Back to the drawing board - kill algae, remove dead algae, etc.
    Get a K2006, so you can manage chlorine levels and raise them to the high shock range, and CLEAN UP that algae. It is NOT something you have to live with!
    May 2013
    long island
    I love the polaris 9300..used it 3 times now very simple set up and operation...however..it doesn't get every inch and I'm still left with small leaves scattered around. I'll never get them all with the net too. Perhaps i should have gotten the one with the remote
    DE 3620 Hayward. 16x36 Inground rectangle (1995). 7.5 ft deep end 3.5 ft shallow. loop loc cover with mesh panels
