Results 11 to 11 of 11
Thread: What to do with test result water?
    Default Re: What to do with test result water?
    Just be aware that the reagents ARE chemicals and some of them have some hazards.....DPD is an aniline derivative, OTO is dissolved in hydrochloric acid to make the test reagent, TA titrant is usually sulphuric acid, CH buffer is sodium hydroxide. Not really more dangerous than many household chemicals we use every day but they should be treated respectfully and disposed of properly. Dumping them back into the pool just isn't a good idea, even in the small amounts used. Some of them are adsorbed through the skin so if you get them on your hands it is a good idea to rinse them off right away. That is why I do my testing next to a sink. People have a lot of respect for working with muriatic acid. The chemicals in the test kit deserve the same kind of respect even though they won't cause the immediate damage that an acid spiil can cause and we are using them in much smaller amounts.
    Just my 2 cents!
  1. Any Water test result spread sheet or software available?
    By Heavyhook in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-17-2012, 06:35 PM
  2. Weird test result for Alkalinity
    By sabres07 in forum DPD-FAS based testing
    Last Post: 08-15-2012, 12:14 PM
  3. treatment result
    By essikr in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-23-2008, 02:00 AM
  4. Interesting CC test result
    By donfranko in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-21-2006, 05:10 PM
  5. Just opened pool for spring, test result questions
    By Beachnut_PA in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-01-2006, 09:07 AM
