Re: Leaving Pump On With High Pressure
When cleaning out my pump screen basket, the water drains from the lines back into the pool, and I like to run the pump to ensure the pump has kept its prime, and doesn't take to long to draw the water back up. This takes a minute or two.
To prevent draining the water lines, occasionally I'll turn my sand filter to the closed position , clean the basket and then return the filter to normal position. One day last week, out of stupidity, I forgot to return the filter out of the closed position.
During the day the timer ran the pump for 4 hrs.
When I returned the filter pressure gauge was obviously running high (~25psi, typically runs at 15).
When I returned the filter out of the closed position, pressure went back to normal. The only visible damage I could was a small leak (a few drops/minute) at the PVC fitting on the high pressure side of the pump. I replaced it and things look OK.
I recognize I'm extremely lucky, is there anything else I should look out for.
Carl Schnurr
96,000 litre inground, vinyl liner, 1 HP 1speed pump, sand filter, SWG, installed 2005.
