Thread: Pump Not Priming
    Jun 2012
    Pennsylvania
    Cool Pump Not Priming
    18x32 Oasis, In In Ground with Vinyl Liner. Pool has run fine past two summers. Just tried to backwash pool and pump will not prime to draw water back to filter. Also tried to run in filter mode with no luck. Have tried to add water direct to lines and to pump baskets. Bled air from filter, but not getting any water to it.
    Any help appreciated.
    Default Re: Pump Not Priming
    I know this sounds like a stupid question, but is your pool's water level high enough to allow the pump to prime? Mine won't if I don't have at least 4 inches or so of water above the top of the skimmer basket.....do you hear any odd noises coming from around the skimmer while it's trying?
    Any possibility of an air leak--is the lid on the pump basket tightened securely?
    Shifty is offline Registered+ Thread Analyst Shifty 0
    Jun 2012
    Pennsylvania
    Janet,
    I had a similar problem the other day. I could not hold prime. It kept fluctuating. The reason I couldn't hold prime was because my water level got too low on the skimmer. I added water just as you suggested in post #2 and the prime held.
    American Titan SS DE Filter; Multiport; 18'x36' grecian 24K gal IG krystalkrete (super blue) plaster; BBB and trichlor pucks for CYA; Hayward SP3400VSP Ecostar; Taylor K-2006; The Pool Cleaner Auto Vac (4 wheels)
    Jun 2012
    Pennsylvania
    Thanks for the feedback.
    Turned out that it was a pump issue (Hayward 1HP). Impellar was rotating, but not getting enough suction. Seals worn-ended up replacing motor, but learned a lot about maintenance of gaskets, seals, etc and need to address any small leaks immediately.
    Yeah, there's nothing like having to take the pump apart that will teach you the lesson of: Don't ignore that little leak, because it can cause you BIG problems down the road! Glad you got it solved.
  1. Suction Leak Causes Pump Priming Problems
    By Tirwin in forum Pool Equipment & Operations
    Last Post: 05-23-2013, 10:53 PM
  2. Pump not priming
    Last Post: 06-06-2008, 06:39 PM
  3. Priming the pump?
    By denanbob in forum Pool Equipment & Operations
    Last Post: 07-04-2006, 12:58 PM
  4. Pump Not Priming Or Sucking Water
    By arbutler11 in forum In-Ground Pool Construction and Repair
    Last Post: 06-25-2006, 08:31 PM
  5. pump priming above pool
    By mizzouguy in forum Pool Equipment & Operations
    Last Post: 04-22-2006, 07:07 PM
