Thread: Pump Not Priming
    Default Re: Pump Not Priming
    I know this sounds like a stupid question, but is your pool's water level high enough to allow the pump to prime? Mine won't if I don't have at least 4 inches or so of water above the top of the skimmer basket.....do you hear any odd noises coming from around the skimmer while it's trying?
    Any possibility of an air leak--is the lid on the pump basket tightened securely?
    Shifty is offline Registered+ Thread Analyst Shifty 0
    Jun 2012
    Pennsylvania
    Janet,
    I had a similar problem the other day. I could not hold prime. It kept fluctuating. The reason I couldn't hold prime was because my water level got too low on the skimmer. I added water just as you suggested in post #2 and the prime held.
    American Titan SS DE Filter; Multiport; 18'x36' grecian 24K gal IG krystalkrete (super blue) plaster; BBB and trichlor pucks for CYA; Hayward SP3400VSP Ecostar; Taylor K-2006; The Pool Cleaner Auto Vac (4 wheels)
    Jun 2012
    Pennsylvania
    Thanks for the feedback.
    Turned out that it was a pump issue (Hayward 1HP). Impellar was rotating, but not getting enough suction. Seals worn-ended up replacing motor, but learned a lot about maintenance of gaskets, seals, etc and need to address any small leaks immediately.
    Yeah, there's nothing like having to take the pump apart that will teach you the lesson of: Don't ignore that little leak, because it can cause you BIG problems down the road! Glad you got it solved.
