Thread: Pump Not Priming
    Jun 2012
    Pennsylvania
    Default Re: Pump Not Priming
    Thanks for the feedback.
    Turned out that it was a pump issue (Hayward 1HP). Impellar was rotating, but not getting enough suction. Seals worn-ended up replacing motor, but learned a lot about maintenance of gaskets, seals, etc and need to address any small leaks immediately.
    Yeah, there's nothing like having to take the pump apart that will teach you the lesson of: Don't ignore that little leak, because it can cause you BIG problems down the road! Glad you got it solved.
