Salt water generator
Hi. New here. Not new to pools. I have had this particular above ground pool (Namco 21 x 52 sand filter) for 6 years with no problems. I exclusively use liquid shock. I've never had green, slime, cloud or any other problems. Vaccuum every day filter runs for 12 hours. Ph is always a bit low (kids use goggles) but it keeps my FC good. I shock to 10 every week. So....here's the questions...I just switched to intex krystal clear saltwater generator. Put in the minimum salt level ran for 24 hours without generator on and then switched it on. Ran boost cycle. Checked salt level (said 2972) and FC (said none) and copper (said none). What do I do? Add more salt? The generator isn't saying low salt. I wanted to switch to make it a little easier for me but this isn't easier. Thanks in advance?
Kristen
