"Everything is testing bang on my strips" is part of the problem....strips are not very accurate. They are good for testing whether there 'is" or "is not" chlorine in the pool, for example, but are not reliable for saying "how much". Do yourself a favor and get a drop-based test kit. It will save you tons of money and headaches in the long run. The one we recommend is the K-2006--check out the teskits link in my sig. We need to see numbers posted for your water parameters to be able to help you much.
What is your source of fill water? If it's a well, odds are pretty good you have a metals issue. If that's the case, the water discoloration you are seeing isn't dangerous, even though it's not pretty. If metals are the issue (and you can get them tested for at your local pool store, or if it's municipal water, call your water dept for an analysis), then you need to read through this sticky for info on what to do from here (until your registration is complete, you may have to log out to read it)
http://www.poolforum.com/pf2/showthr...est-for-metals
http://www.poolforum.com/pf2/showthr...water!&p=95155
Hope this helps!!
