Thread: Fastest way to clean the water up?
    Jun 2012
    Lexington, S.C.
    Cool Fastest way to clean the water up?
    Algae got me and now that I have my levels back in check I can't clear the water. I have a 20,000 gal. IG Pool sand filter 1.5 hayward pump. Thanks and I'm a first time caller!!!
    Default Re: Fastest way to clean the water up?
    Hi, and welcome to the forum!
    Can you define "levels back in check"? If you would please post a set of test results taken with drop-based testing, no strips, we'd be glad to look at it and see if we can help
    Please fill your pool's information into our pool chart to make it easier for us to help you.
    Pool Chart Entry Form
    Pool Chart Results
    membership upgraded -ben
  1. How to keep water clean without running pump and filter?
    By mike83 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-01-2013, 08:42 PM
  2. Fastest way to add CYA???
    By bobcat in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-08-2011, 12:16 PM
  3. Water Clean - but now too much FC
    By jbalcorn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-05-2008, 08:21 AM
  4. How do you clean you water bags?
    By poolbee in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-29-2007, 11:55 PM
  5. Help to clean your water
    By IMherDad in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-28-2006, 09:33 PM
